clio 197 f1 keyless can u start with key
  clio sport 197
Hi i have the clio 197 f1 with keyless push button start there is no slot for the key card , in the keycard there is a small spare key i can open my car with but can u start the car from there , once u open door with key i thought mabie the ignition would come on then u cud press the button or mibbie there was somewhere to put the little silver key in to start it but cant find anything can anyone help a guy out been wondering since i got the car thanx
  SG 200
As far as I'm aware, so long as the key is in the car, you can start it. There should be no reason to use the key itself to start the car, as it should work even if the battery in the key is dead
  Megane 275 trophy006
As above look below the start/stop button to the right at the bottom. There is a slot there for it but you cannot start the car without a foot on either the clutch or brake and a press of the start/stop button.
That key is a backup for if the keyless entry fails. The only place for it is on the passenger side door handle.
  clio sport 197
No i havent stole it lol just wonderd if it cud be stared with the key my car dosent have a slot for they keycard so it was just incase the key card failed i can open the door with key but dont know how to start it pushing the start button dosent start it after opening the passanger door with the key
Typhoon
Gangsta
Your keycard slot will be under your centre console. Right hand side.
