I changed the door loom on my 172 cup 2002 as had a melted mirror switch ages ago
Disconnected battery, stripped door card off, changed loom, changed blown fuse and reconnected battery all on Saturday
Verified mirror switch worked fine, as did radio and clock as seem to be on same fuse
Sunday eve went out to start car for first time and doesn't turn over. I assume red light with ignition on means immobiliser not off
Key fob locks and unlocks fine, though initially drivers door didn't lock but I thought maybe I'd not pushed the connector on enough. Drivers door seems to have magically fixed itself.
Read lots of posts giving different things, have disconnected battery, turned key to first click, reconnected battery still nothing. Repeated with key on second click, nothing. Also read about pushing central locking button on dash for 20 seconds, turning key mor than 20 times on and off but all make no difference... Car wont turn over and immobiliser red light stays on after all other go off. Car only came with one key so can't try another, but must be related to battery disconnect as has been fine since I bought the car 12 months ago
Any other ideas for the correct sequence when reconnecting the battery?
Thanks!
Thanks!
