Big_Steve_T
Wonder if you can help me out with something that's puzzling me on my Mrs's new Clio Sport.
It's a MK1 172 in very good overall condition.
But for some reason on the drivers side Electric Window Switches you PULL UP the switch to LOWER the drivers side window :headno: :headno:
Then on the Passesger side switch you PUSH the switch down to lower the window????
At first i thought that surely some numptey brain has just had the window switches off and wired them in wrong but when i had a look at the back of the plugs it appears that the wires seem to be the same colours in the similar terminal numbers making me think that they're in the right place????
I switched the wires on the terminals at one point and got the switch working correctly but didn;t leave it like that because of comparing it to it's neighbouring switch.
I've searched the boards and seen people have problems with Relays & Electronic Modules (can't remeber it's name), do you think that could be the cause of the problem, or is it just simply that the wires are on the wrong terminals of the plug???
Any ideas?????????
Any ideas?????????
