Clio 172 gearbox oil leak
  Clio RS 172
Have a phase 2 172 with a gearbox oil leak.
also has a knocking when driven hard
i have removed the gearbox from the car, does anyone know of a specialist that will look at the gearbox and repair it?
have considered the option of a second hand unit, but could put it in and end up with the same problems!
thanks Matt
  Clio Sport 172
Is it just one knock on acceleration or deceleration, or both? If so it's probably the exhaust hitting the subframe, check the top engine mount, my original tore in two within 6,000 miles from new. If it's a constant knocking with wheel rotation, then it could be the gearbox or drive shaft.
DaveDreads
Without a more detailed description of where the knock's coming from and when it happens,
it's pretty hard to diagnose, it could be any number of things.
  Clio RS 172
Its a a constant noise that increases as I drive harder, which for me leads to the gearbox
