Ive just brought an old Clio for a runaround car because the other half keeps pinching mine.
Engine wise its sweet as anything, couple of problems with it as to regarding the brakes and clutch.
First of the brakes are very weak, Im 100% going to take it to a dealer and get both these problems sorted because its pretty clear if you ignore problems with the brakes your pretty much suicidal.
Theres no constant breaking, its either nothing or full on heavy breaking, Does that sound like worn pads?
The pedal feels a bit weird too, almost like theres air in the system as I can hear a sort of squidigng noise if I pump the pedal after leaving it for a while then the noise goes away and the pedal sort of gets stiffer.
Now onto the clutch, the pedal is really stiff, my mate said it could be that one of the bearings gone on it, The clutch engages and bytes fine just that its really stiff.
Anyone want a go at est. on how much this is going to cost to get put right?
