Brake line info
I am after the following info so I can get some custom braided hoses made up as the 197 lines are just too long:
What is the length of the front flexi hoses on a 1*2?
Also, what are the 197/200 Brembo flexi hose fittings called?
MRBILLYUK
  FF Jeden Osiem Dwa
The length of the flexi hose on a 182 is 35cm from the ends of the fittings .
Matt e
Do you know the length of the 197 hoses?
  172 cup, Impreza P1
The 197 lines I currently use are too long and I don't like having to cable tie them away from the wheel..
I just use 8mm P clips and drilled some mounting points next to the strut that holds links the chassis to the wishbone.
i can take a pic if you need.
