Brake light switch?.
  Focus RS + S3
What sort of a job is a brake light switch to do on a 172 under the dashboard
Will take you all of 30 seconds, twist it 90degrees, unplug it, job done.
I dont know if they fail, but if your looking to hange it as its bringing up esp faults then you can adjust them very easily
  Clio 172 cup
Ye I had it plugged in and it was saying that was as fault need it sorting as mot is around the corner how do they adjust??
  182
I had to replace mine. With new one pull plunger all the way out. Fit back onto car pushing the brake pedal all the way down. Release. It'll click a few times. Repeat if necessary but i found that worked for mine
  Clio 172 cup
Cheers lads il order one up and give it a whirl
