anyone fitted a
  williams and trophy
yeah they all the same stick..........but they not exactly an hours take off refit job arre they lol
when i fitted mine......got 1st 2nd 3rd 4th gears, no reverse or 5th
adjusted linkage again n again to compensate............still 1 2 3 4th gears
on closer inspection found that the lift up bit wasnt liftin high enuff to clear the gate for revers.......so shaved about 5mm off the nylon block, hey presto ........got reverse
as for 5th..........the bolt on the bracket on the btm of the stick holdin the linkage on was foulin the tunnel.........chopped the bolt rite down about same 5mm off...hey presto now have reverse and 5th, as well as 1234th
put the heat shield back on........guess wot? lol
yep ........the btm of the stick now fouls the heat shield, so am gunna have to take that back off and adjust it lol with a fukkin hammer
