Another rough idler... but cuts out
  Evo 6 TME, Clio 172
Hi all another rough idle thread... but this is my 2nd 172 and is alot worse than my last one.
If I start car cold it idles fine while the ecu keeps the revs above 1k, as soon as the revs drop below 1k as the car settles it idles like it's aggressively cammed, and whole car shakes, when I pull off it's very hesitant below 3-4k, if I keep it going it clears
But sometimes when coming to a stop and going in reverse it cuts out, not all the time, but the car needs some revs to stop it stalling.
I run the car on vpower or momentum so its not the fuel. It's had new plugs, filter, and lambda recently so where next? I've seen about cleaning throttle body, and replacing map sensor? Are they common fixes or just a waste of time? There are no warning lights on either.
Wanting to polybush engine mounts but it shakes enough as it is
Sent from my SM-G950F using Tapatalk
  Evo 6 TME, Clio 172
Coil pack I reckon.
Could be coil pack, I'll maybe try one of them, don't want to throw parts at it unless I know or have a good chance of it being one, is there any way to test coil pack? Or is it just change and see if it works?
YorkshireKyle
Not all gingers stink of piss. But I do.
An injector would have to be really bad for it to cut out
Pull each ht lead off of the coil pack when running, if it gets lumpier then it’s not that one. Do the same for the injectors too
  PH2 172
Just take half and see how you get on.
