Martin_172
hi, if an alternator is going to die will it do it over time or just die one day? the problem being is that because i cant drive yet my cars not getting a drive about that much and if i am cleanin it or somthing and have music playing i only get about 10mins before my battery goes flat and wont start the car (only thing changed is the head unit, no amps etc) and then today i had music playing but had the engine running and when i turned the engine off i forgot i hadnt put the windows up, so i done it and they went up REALLY REALLY slow and sounded like the battery was going flat, so i started the engine to check if the battery was flat and it died on me and cut out, so i started it again and it tried to cut out but i gave it a rev to keep it alive.
now is my alternator dying and not charging properly or is it just because its only idling at 500rpm and not really charging it quick? ive got plans for an amp, front components and a sub, so should i upgrade the alternator and/or the battery?
