Albi blue 197
i know this is a common thing with the airbag light and ive had a good look about but i cant find the answer im really looking for... basically ive had a ph2 authentique and i have put in ph1 sport seats in.. there different plugs so i wired in the seats with bullet connectors , but there was 2 wires spare that had nowhere to connect, so i had a look on here and found for the airbags you need to use 3 to 5 ohm resistors so i went to maplins and got a 3.3ohm resistor with a 10% tolerance i tested resistors first to check it wasnt too low and it measured 3.6ohm so it should be okay ive put it in and the lights still on .. i tested resistor again to make sure its okay and it still is so connected it back and still lights on what should i do cheers in advance
