172 cup tie rods and track ends
Chambers_RS
  Clio 172 Cup&Leon K1
I believe the first line number you had on the other thread is correct for the 172 cups and 182s.
I can check when I'm back at work Monday as i supply Beaniesport them weekly.
  172 rag
Use FAI 556263 or First Line ss6263 if I remeber correctly and Lemforder ends.
Have a search but 99% these are the correct part numbers.
Chambers_RS
Ss6263 isn't a first line Partnumber.
The FTR5277 Fordy found is the correct part for cups and 182s. GSF branches will stock these
  172 Turbo
RENAULT CLIO Left Tie Rod Axle Joint FTR5277 is what I used - The ebay title makes me think they are sided but I just used two FTR5277
