Trust me the only issue you will have is them not making proper connection
Ive not got the brown plug. Mines black.. pic:
There should be three wires going into the plug - bridge the two that aren't black and the airbag light will go offI need to put a resistor in? across what colour wires?
I have seen a few people using 3.3 ohm on here...
Erm, I think I only need two dont I? Might have to nip down to maplins I will keep messing about with them for now though...
Have I done it right though in the above pic?
and whats the exact resistor you used mate, thanks!!!
I bought x10 3.9 Ohm 0.6 Watt resistors from Maplin and they did the job perfectly (80pish i think)
however, as you've already got the resistor (the long black thing in your picture) then you could just re-attach it using some block connectors as in my photo and it should work!
