So the problem started after I removed and refitted my injectors and top inlet. Took the car out and was fine for 10 minutes, then developed a bad misfire. This is mainly when warm and under load.
On investigating I pulled the lead off the injectors, pulling the leads off one injector made no difference while the others made it run worse. So I fitted a new injector, but hasn't helped.
So now I am thinking leads, coil or plug. But am I right in focusing just in this cylinder due to the above?
