Got some lol.get a bag of swearwords if you are doing it on the floor.
Is a deep socket a necessity due to the other end of the bolt poking through the nut too far? Or will a normal socket with plenty of extensions be Ok?Fitted power flex black to mine a few weeks ago, didn't need any special tools, deep socket and extension as a couple of the clamp bolts are accessed through deep recesses in the rear subframe. Used a little prybar to wiggle the rack out enough to change the bushes. I did mine on the floor with the engine out and it was still fiddly so yep, bag of swear words required!
My tool kit is pretty good to be fair but I lost my deep sockets to the wife's tidying up, along with my camber bolts which never saw their way to the car!Can't remember to be honest, you don't even need a lot of extensions the nuts only maybe 3 inches into the subframe. Though if you haven't got deep sockets your tool kit must be pretty limited? I'd be worried about starting a job that is going to disable the car if you're not sure you've got everything you need but I guess that's why you started the thread so not much help!:tonguewink:
