I would love a disc with the above dimensions but 290-295mm. Shall keep an eye on this .
Toyota avensis mk2 t25.
295mm x 26mm 4 x 100 pcd , 55mm centre bore (needs maching to 60..1)
Offset 49.2mm
maybe a better option than re drilling the corect pcd.
Offset 49.2mm
This is Scenic discs behind 15's on wilwood calipers.
My willwoods are on the redrilled 295 5 stud disks and fit under 15s with no spacers.
My tarox 6 pots use scenic 300mm disks but require big spacers, Im probably going to remake the brackets to use the 295 as well.
Chip are you running the jamsport kit. If so where can you easily get replacement discs last time I spoke with jamsport they wanted ££££ for some discs :/
It would be perfectly fine mate. I've ran re drilled discs before with no issue.Emailed about these and there actually 5x100,
The 4x100 was a mistake.
How safe would it be to buy them and redrill them 4x100 for the clio??
