Right.
I'm a novice with, well, anything to do with maintenance and junk. Trying to work out if it's worth doing speaker upgrades or not.
I was originally thinking of doing amps, components, the works, but that looks like a vast amount of work that I'm really not liking the look of.
for instance, if I used the existing speaker wiring, how would I get the front component wires to link up into the front outputs on the amp?
so, in the name of naming life easier, I was thinking of either the Hertz 130's or Pioneer straight-swap comps up front. IF being run off of your average Alpine 4x50w unit, which would be the better bet?
the pioneers obviously just attach to existing wires, but the Hertz get better reviews for what sounds like not a vast amount more grief?
finally, for the rear pods, I was toying with the idea of the phonocar mid-basses as seen in caraudiodirect, with a filter in-line? Only thinking of changing because there's something amiss in the passenger-rear door pod that needs looking into, may as well get some new gear in there.. or just get a pair of simple co-ax?
Help appreciated,
Help appreciated,
