Dicky Belly 3
Hey. I've noticed that when in gear my gear stick wobbles crazy lots all around.
I searched and found that to check, you remove your gearstick gaitor, if your ball joint housing is okay the black rubber insert should stay put and only the white ball bit moves however on mine the black rubber insert is all over the shop!
Where can I get a replacement please?
Cheers!
Cheers!
