Will std Williams front struts fit any mk1?
  1997 Mk1 1.2
In the title really ,
A nice pair have come up at local breakers and I'm tempted , just wanted to check if theyd fit with you guys first? :)
  182/RS2/ Turbo/Mk1
They will fit but will add positive camber if not used with the longer williams wishbones as well.
And if you use the wishbones, you need the driveshafts and ARB too.
Its kind of "all or nothing" really.
(although you could try camber bolts to correct if you did just the struts)
  94' Valver F4R'd
Would just be eaiser to put valver struts on... Same track width
Williams is wider so full setup would be needed, Wishbone, ARB, Driveshafts ect...
And with the widetrack you'd need the arches too if its a Pov
