And the rartios will be shorter, but i doubt you would notice.
You could tap into the abs and use the OEM as your trigger wheel, work out how many pulses it fires in one turn of the wheel then convert that in a signal to power your speedo, you can buy a adjustable signal conversion unit to calibrate the rate of impulses to MPH.
