white smoke and sweet smell from exhaust????
  172 CUP
Turned car on (172 cup Ph2) and got white smoke coming from exhaust and it smells quite sweet. What could this be???
  182 Trophy #333
is it actually coming out of the tailpipe? If so would definitely suggest head gasket or possibly a hairline crack in the head / block
  172 CUP
Yea out of exhaust (white smoke and sweet smell) not loosing coolant, engines not over heating and my temp gauge needle is bang on centre
  172 CUP
Not sure mate only had it on for about 3 minutes, got to nip out so will find out and let you know by about 1pm
  182 Trophy #333
no idea on price, depends if it needs a new waterpump / head skimming / replacement belts, if its coming out of the exhaust it definitely sounds like coolant is getting into the combustion chamber or exhaust somehow, maybe the gasket is seeping slightly or like i said there could be a hairline crack somewhere, best getting a specialist to check it out before throwing any money at it!
Mine had white smoke this morning but that was because it was cold. Was fine once it was warmed up and had been driving for a few mins
  182 Trophy #333
if it was just water in the exhaust it wouldnt smell sweet though, the sweet smell comes from the burning of the ethylene-glycol in the coolant
Do you get quiet alot of white smoke when it's cold but then goes once warm?
Yeah not a huge amount but you can see it and it goes once the exhaust system is warmed up. I'm not loosing any coolant etc either so I know it isn't a HG issue on my car
The sweet smell however is odd. Never get that
  AB182, Audi A5 3.0
or another sweet smelling substance that's nearby... it needs to be run and checked to see if the coolant drop and if the white smoke goes away. If its not loosing coolant then I don't see how it could be leaking into the chambers.
DrR
  VW Golf GTD
So you switched a cold car on, and it's making white smoke for first few minutes of driving?
Mine white smokes quiet alot when cold but only when I put my foot down a bit, I'm not losing any coolant or anything so is that normal?
DrR
  VW Golf GTD
Every car I've ever seen/driven gives out white smoke when cold.
  172 CUP
Ok so just taken car out for a drive and no more white smoke. It didnt look like cold start white smoke, it looked really thick and exhaust was making a ''puf-puf'' noise and it smelt like syrup. Coolant isn't moving, temp needle is sitting in the middle and exhaust smells like petrol so a panic over nothing.
But thanks to everyone who commented (would rather check with you lot who are far more experienced with these cars than leave it and think its ok)
