ok.....wow
KK - no the magnet wil do nothing, and the ecotek will do a little. I had one for a while, but it broke, didnt really notice much. and tuninng it is a pain in the arse, as sometimes it wobbles loose and screwes itself. Cutting the brake servo line is not a problem, as its just a vacuum pipe. But for 40 quid, why not.
Kona - good idea with the aircon wrap and foil, sounds like a good idea, maybe you could cover the airbox in it too, as this will be hot too.
tohowe - Well, the PBV will only increase fuleling by replacing the regulator and forcing more in. This is because fuel is normally burnt at 15:1, and the pbv will decrease that to 12:1, making more eficient use of the air available. Set it up wrong and it will suck.
in my opinion of getting mods the order should be:
1 filter (the new viper will rock!!!)
2 exhaust
3 datsek uni chip
4 head ported and flowed anlong with the inlet manifold and exhaust manifold
5 cams ( fast road and nothing above)
6 balance and knife edge crank, and increase comp ratio
7 bigger inlet valves
8 faster car
i deally you would want to get the cams and head done at the same time, but if money prevents this, get the head work done forst, then you increase from the new cam will be more fun!!
