WHATS UP WITH MY CAR
IT WONT START AS THERE IS NO FULE GETTING TO THE CARB
THE FULE PUMP WORKS IVE HADE THE FULE PUMP RELAY TESTED. IT WORKS
WHAT ELSE COULD IT BE :confused:
  172 cup,s2 rs turbo
if the fuel pump defo works then it must be a blocked pipe. did you bridge out the fuel pump relay connector to check if the pump is working? did you check for a feed and a earth at the actual pump connector?
