What the f**k is wrong with my brakes
Car  1998 BMW e46 323i
[YOUTUBE]1h52AVysimA[/YOUTUBE]
It used to tick, now it's creaking like a mofo. And then 10 mins later it's fine, no noise??!!
It's been getting worse since I put new discs and pads on. Lockheed discs and Ferodo pads. Just took the pads off, cleaned everything up and greased it etc, but I won't be surprised if it makes no diff. The car brakes well, doesn't pull etc.
It's only noisy under gentle braking, i.e. stop start traffic.
Is my caliper f**ked?
Does the pedal pulse? Have you checked to see if theres a crack in the disc and how much of your pads are left? Sounds like a lack of lube some where (lol at smurf sex)
Did you remove the shims from caliper before fitting pads?
The shims are still on, all clean and smeared with a bit of grease. But I just removed the backing plates that came on the pads themselves. Looked a bit suspect, but I've prob' made things worse.
Disc seems fine, pads are new, pedal feels ok too
i have my brake shims off and mine are fine, others have taken theres off too otherwise they dont fit properly
my old 106 gti done this before and it was one of the slides sticking
It could be the piston couldn't it. I'm guessing they're not repairable, just replacable! Is there a way I could check for certain it's the piston? If the top mount was loose, would it creak under braking?
Just thought I'd update: Took the backing plates off the ferodo pads, cleaned, wire brushed and greased everything. The noise has gone!!!! So far so good
cheers fred. Like i say it's ok now, but if it plays up again i'll know where to look first.
