wössner hi comp... what cams?
  '10 Clio200
hi, i'm building a 172 engine with wössner 12,8:1 and i don't know what to do with the head.
will oem cams with adjustable pulleys work? i also have a renaultsport group N ecu which i intended to use.
any advice welcome :D
thanks.
  172 cup
as far as i know the adjustable pulleys from k tec takes out the vvt so u cant use oem cams so u would need to get some performance cams from k tec which are compatible with the pulleys which they can supply :)
