Very weak brakes... Bordering dangerous.
Since buying the car a couple of months ago I've always felt the brakes are weak.
Haven't driven it too much but took it out yesterday and put brakes to the test.
Definitely something wrong with them.
Peddle feel seems fine, not too hard or soft and is consistent. Peddle travel seems fine too.
When pottering around town you wouldn't notice the bad brakes, as in your normal braking situations they are fine.
It seems to be that once you want say more than approx 50% of braking strength it just won't give you any more.
It brakes progressively and smoothly towards 50% of braking force but no matter how much more force I apply the brakes don't stop you any faster. The peddle keeps travelling as it should but brakes don't stop you any harder.
Tried numerous emergency stops and brakes are so weak even in the hammering rain I couldnt get it to skid, lock up or abs to kick in.
Front discs and pads actually look ok condition. rears well worn.
I have a full set of discs, pads, brake lines and fluid to be fitted this week.
I'm hoping this will cure it.
Does this sound familiar to anyone? It may be a problem somewhere else in the brake system? I can get it all fixed the same time as I do disks etc then see.
botfch
  Clio 182
Swap discs, pads n fluidcheck for leaks etc should sort most problems!
George@RTR_Parts
ClioSport Trader
  need BRAKES? PM me
Your new brake set up will improve things Dan
But you want to check everything is working as it should be while you're at it. Check for sticky calipers (quite common on the rears) and that the servo side of things is ok
George@RTR_Parts
ClioSport Trader
  need BRAKES? PM me
He is flushing the fluid through with decent stuff when he's fitting braided lines very soon so no worries there lads :)
botfch
  Clio 182
Random q's but any particular order you should bleed the calipers on 1*2s?
  clio 182 trophy
Mine were like this before I had my replacements all round from g172 last week. They were scary in the wet. New ones have totally transformed my braking now. Looses speed from 70mph very well imo.
Start with the furthest away from master cylinder...
Passenger Rear
Drivers Rear
Passenger Front
Drivers Front
Lol. Well that's me completely wrong. :p
Ah well. That's good. Hope mine will be sorted so can drive it properly and take it to brands hatch. :D
George@RTR_Parts
ClioSport Trader
  need BRAKES? PM me
Cheers. Guy doing the brakes with me is a mechanic so hopefully he should be able to check most of it over. He's not familiar with clios. Mainly does our work vans etc.
Sure he'll be fine mate. just remember the tips I said ref the DS2500 fitting and the spacers behind rear disc correct way round (tapered towards car) retorque rear hub nut to 175nm and jobs a good one
Mine were like this before I had my replacements all round from @G 172 last week. They were scary in the wet. New ones have totally transformed my braking now. Looses speed from 70mph very well imo.
Glad to hear you're pleased with them :approve:
I'm sure they will be!
Also ref bleeding the brakes, as what Tunst says. Furthest from MC first. You'll have plenty with a litre and Superblue is really easy to bleed through properly due to it being blue
Great. Will remember to do all that. :)
Noticed on the tin it says not for use on the road due to it's colour not conforming to road use?! Would that even be picked up on an mot? Never heard about brake fluid colours before?
George@RTR_Parts
ClioSport Trader
  need BRAKES? PM me
It has recently in some American states due to the colour. I've been using it on road/track for years, nothing to worry about it.
You can alternate it with "Supergold" when you need to as this is the traditional amber colour.
Fitted new discs, pads, hoses and full fluid change and brakes still have the same issue, lack of power. :(
Anyone have any ideas? Master cylinder?
There's Def no air in the system. Was thoroughly bled.
  Arctic 182
Bump. I have the same issue after changing pads, discs, brake lines and fluids. My brakes are still poor, my girlfiends 1.2 extreme brakes were sharper.
botfch
  Clio 182
Have you bedded in the new disks and pads yet?
Also are the sliders moving freely?
Is ABS working?
Is ABS working?
Yea mate. Gave them a good bedding in. They feel the same as before. Lack of braking power/pressure.
Sliders were all cleaned and greased.
I don't actually have enough brake pressure to engage abs to see of it's working.... In the dry or pissing down rain. The abs won't kick in neither will the wheels lock up. Just not enough force to do it.
Any other ideas. Thanks for the reply.
botfch
  Clio 182
I'd have a look at the seals on you Master cylinder either that or air in the system somewhere.
Wouldn't know where to start with that one. :p
I need to take it to a garage but it's taking it somewhere that you can rely on is the issue. Don't want to get my pants pulled down!
Bled the brakes thoroughly, flushed new fluid right through.
botfch
  Clio 182
Fred @BTM is prob your best bet for a garage.
  Phase 2 172
have you checked the pistons in the calipers are free, could be a seized/seizing caliper, un bolt the caliper from the carrier ask someone to push the pedal with little pressure and see if the piston moves out (careful not to make it pop right out), then push it back in. if its seized repeat this a few time and it should free it off a bit
Well something bizarre has happened.... Brakes have repaired themselves!! :D
It happened while on way home from London. I was feathering brakes with left foot when on motorway to help bed new discs and pads and then I touched brakes for 3rd time and peddle went a lot harder. I thought 'oh no what now?'
When I came to slowing down at slip road I tested brakes and they were massively strong!!
Several emergency stops later (with no cars behind of course) and the brakes are ridiculous, feels like back tyres are coming off ground! Abs kicks in tyres screech etc Proper braking finally! I'm so relieved/happy!
So it seems callum was probably right with the sticky caliper piston. As it seems to have released.
Also out of the ten or so E stops I did, on one of them the car braked a lot harder on one side as you could feel cars weight shift to one side.
So I may look at buying refurbished calipers or maybe a seal kit for these and strip them down myself.
I'm so relieved and thanks to any suggestions from everyone. :)
George@RTR_Parts
ClioSport Trader
  need BRAKES? PM me
Good to hear Dan, :approve: bedding the DS2500 pads in properly is important
I'd still look at the brakes or get it looked at if you think it's pulling to one side or got a sticky caliper. Then you know they're sorted
