clio 172 cup
Hello
Well i have a clio 172 cup. i get a slight misfire below 2000rpm. BUT.... this only happens after i have been for a run in the car. ie i can start it up from cold , the car is rough when cold and pops and bangs on over run but no misfire. it will heat up to the running temp and no misfire. if i turn the car off for 5min to 1 hour and return to the car i have a misfire below 2000rpm.
Note,: no warning lights on dash board at any time.
when the temp outside was very cold i was not getting this problem but now the temp is increasing outside its started again.
any ideas ? anyone had this before?
im thinking upstream lambda? but i do not know.
any help appreciated.
Chris.
Chris.
