VERY loud metallic Sound
-J-
  RS2'ed 172 Cup
I am getting a Very loud metallic sound from the car at about 4k Up.
Happens under Acceleration also in neutral if you just rev the car up and on Run Down.
Sounds like a Washer is loose and resonating but much louder.
I am not sure, but I *Think* its coming from where the Exhaust joins the CAT, I have checked the Bolts and they are tight.... But as I say i only Think its coming from there its hard to tell, Could be further forward in the Engine Bay or somewhere.
Any Ideas? Any Known issues?
I Did... Tried "4k Metallic" "Exhaust Rattle" "Metallic noise" And couldn't find anything related.
Thanks for you "help" anyway.
i was helping, i told you it was a known issue, i.e one of your questions.....:nono:
it is either the heat shield, or the sleeve that the mani / cat joint bolts too.
and heres a few of the threads with people saying the same......
http://www.cliosport.net/forum/showthread.php?t=398178&highlight=rattle
http://www.cliosport.net/forum/showthread.php?t=382310&highlight=rattle
http://www.cliosport.net/forum/showthread.php?t=376721&highlight=rattle
http://www.cliosport.net/forum/showthread.php?t=342420&highlight=rattle
lots of love xxx
  Octy VRS
I've had 2 of these metallic rattles on my 182. First result was something in the silencer that had come loose, second was the water pump. That meant a new one.
  182
I had a lose bolt on the alternator once, sounded like the heatsheild but obviously wasn't.
  IS PH2 172
exhaust mounts is instant thought... as was getting the same noise untill i did the ultimate ghetto fix on the rear mount using a flannel and green garden wire
-J-
  RS2'ed 172 Cup
Its not the Mounts as they are less than 6 months old.
I would imagine if it was the Water pump it would be a constant noise?
