www.renparts.co.uk
Bought a valver off a numpty for 300 quid. He has just put another engine in it from a crashed valver which is hit mates so i know the engines strong.
1) Problem is he has started putting a different loom in (god knows why). I have a complete loom ready to go in but i just wondered if there is a guide available on fitting this (IE where everything plugs in). Ive got good mechanical knowledge so im generally pretty good but im all new to this. just looking for some tips.
2) he has misplaced the ECU when he fitted the new engine will any valver ECU be ok? He thinks he has 2 back at his workshop so im just hoping i can use either and they will be ok.
3) as its not running at the moment i sat in the car and tried to select each gear. When you let go of the stick in neural it springs to the right rather than the middle. Reverse and 2nd also don't seem to be able to select. Is it the way the slector rod has been fitted? or sound like something else?
thanks
josh
thanks
josh
