after i hit the kerb in the ice with the o/s wheel, i have had work done (see discussion post) to fix the suspension and alighnment (lower arm, bushes, wheel bearing) but have a loud rumble/groan that rises with road speed. It gets worse when you back off the throttle, and when you turn a bend to the left the noise stops, and gets worse when you go right.
This leads me to think its a buggered diff? am i right? if so can you fix it or is it a new box time?
cheers people
