trying to wire my sub and amp up
  clio 1.2 mk2 phase 1
and failing so far ! got everything wired up and the subs not working.
rem into amp and headunit
earth on a good point and to amp
red and black connectors are plugged into the head unit ok but dont really know if i put them on the in or out on the amo (dont matter because ive tried every possible way)
same with the sub wires not sure if i put them on left or right but ive tried every possible way)
sub works ive tried it on the door speaker wires
any help would be great
TheEvilGiraffe
South East - Essex
Have you told the HU that there's a sub now ?
Probably an option to put sub on, so it's only sending signal down the pre-out when it needs it.
  172cup
If the amps getting power and not shorting out it is most probably your RCA cables fault. Double check you ve used the HUs sub out and not the usual red and white speaker output as alot of HU's wont send the signal for a sub using the normal output, usually a black set of leads hanging loose you need to look for. Faling that you re sub may be goosed most probably the first option though if you ve got a good earth.
  Polo + Micra
this may sound stupid but have you got the hpf enabled on the amp?
also is the gain set too low ?
dont know what hpf means but on the amp it goes from 120h to 3k ive got it on full and same with lpf and gain. x-over is switched onto hpf and super bass is on 12db
  Stripped yozza'd cup
You can't just guess and plug stuff in wherever.
You don't want the x-over on HPF for a start.
The gain is not 'volume', you don't just put it on full, set it to about a 1/3 to 1/2 as I'm guessing you dont have a volt meter?
You also don't want your low pass filter set to the highest setting.
this is the back of the headunit as you can see in the bottom right the are 2 sockets 1 red and 1 white this is where i plugged my cables (it says sw/f at the side of the sockets)
just about see it theres a blue and white cable thats what ive attached my rem cable to
this is where ive attacted the earth cable
this is the amp, ive put the power cable in the b+ , the rem in the rem and the earth in the gnd
put the wires in the out and in sockets tried all combos
the headunit ive got is a alpine cde-9850ri
this is the user manual
http://safemanuals.com/user-guide-instructions-owner-manual/ALPINE/CDE-9850RI-_E
page 18 and 19 are about setting up the sub and amp, followed the instructions and made sure the sub was swithed on and that it was turned up full
it also mentions the ic setting and says
Connecting to an External Amplifier
When an external amplifier is connected, sound quality can be improved
by stopping the power supply of the built-in amplifier.
• No sound is produced by the system when the power output is set to
OFF.
DEMO ON / DEMO OFF (Initial setting)
MP3/WMA
CDDA (Initial setting) / CDDA/MP3
CDDA : Only CD data can be played back.
CDDA/MP3 : Both CD data and MP3/WMA file tracks can be
played back.
External Device
POWER IC ON (Initial setting) / POWER IC OFF
POWER IC OFF : Use this mode when the front pre-amplifier of
the unit is used to drive an external amplifier
connected to the speakers. In this setting, the
head unit’s internal amplifier has no output to
drive speakers.
ive tried the sub while this has been switched on and off
right well ive not got a clue do you think this is where im going wrong or just good advice for when its set up and working
  172 Flame Red '53
When you have it all wired up and the headunit on does the Power light on the Amp come on?
You will be best of getting a multimeter so you can see if you are getting 12V from the power and also 12V from the remote when your headunit is on. you can get them from somewhere like maplins they got one on offer atm at £7.99.
  Polo + Micra
you need to set it to lpf (low pass filter)
then point the lpf knob to the a of super bass
set super bass to 0
turn the gain down to min
then plug it all in play some music at the level where it starts to sound bad then knock it back (e.g sounds bad at 24 then set it to 22)
turn off any bass boost, eq etc on the hu (apart from sub level iirc on alpines set this too max)
then turn the gain up to where it starts to sound bad then turn it back a bit so it sounds ok then a little more
How do you have the sub wired? It should be from the positive of one channel, to the negative of the other channel... Assuming your amp is bridgeable?
I'd suggest asking someone that lives nearby / an audio shop to help you out. It can end up costing you a whole lot more melting stuff by experimenting.
  ph2 clio 172
if the amp is defo on, you could always try plugging in an ipod/mp3 player via a headphone jack to phono socket lead (maplin will do em) then see if you get sub comning out, then you at least know thats all good. then work your way back from there
  renault clio 2.0 172
Try new remote cable, my sub wouldnt work when i first fitted it and couldnt work it out cos had power there but yet it wouldnt work, fitted new remote cable and worked straightaway
  Golf GT & A4 Avant
If the light is coming on on the amp, then it is being turned on by the headunit. this doesn't mean it's getting power to it to drive it. check the fuses again on the amp and the main live feed from the battery. double check all connections. as if it's not a perfect connection then it'l go into protection mode. I'm sure I used the earth on the rear lights, but to be honest in your pic of the earth, it doesn't look great.
i had a good look around for a earth and thats the only one i found really . i was going to use the bolt thats holds the back part of the rear seats in place but couldnt get the flaming thing undone. thought about the rear lights but cant see how such a small bolt can hold a thick wire in like that. do you know of any other good earthing points
  172cup
Take the boot carpet up and use the bolt holding the rear bench in place. That earth does look fairly weak. Start at the battery and check every connection until you reach the subs. No doubt it will be something silly you ve forgot.
ive tried that earth mate as mentioned above but cant get the bolt undone
ok this is where im at
gone from the front to the back as suggested looking for anything wrong
power wire goes from the battery to the amp (fuse checked again and looks fine)
rca cable goes from the headunit to the amp
remote cable goes from the headunit to the amp
sub goes to the amp
earth cable goes from the amp to the bolt that holds the seatbelt in
also tried another rca cable and not another remote cable and still no sound from the sub
  Impreza WRX
well at a guess, after what you have been going through, i would have a stab at faulty head unit. Dont suppose you have an old one lying around? or just borrow off a mate for 2 mins, to double check if the RCA ports on your headunit are bad
  Polo + Micra
or just get one of those leads from above an plug it into an mp3 player
  Ph1 - 172
What sub are you running and what model number is the amp?
If the sub and amp are running at the incorrect ohmage this can cause issues like this.
It may also be a good shout that the head unit has a fault somewhere.
Easiest way to find the problem would be to firstly try a different head unit. If this produces no change, swap the sub to an alternative that is definatley matched to the amp. If this is still not working then your issue is in the amp/amp wiring.
It sounds like your wiring is ok from what i have read. The issue sounds like it is one of your components on the system.
  ph2 clio 172
thanks everyone for making what I suggested with mp3 player clearer!!! usin gphono leads, this will rule out the rca cables or head unit preout.
however looks like you have done that already.
what I would suggest is you work out if the sub works, then the amp etc.
is the sub in a box, if so was it pre pruchased, is the sub wired to the terminals inside the box. if you dont know get the sub and plug it in to any old hifi at home, it will run full range but you will at least know it workls.
then polug any other speaker you might have (keeping the volume properly low) on the headunit and turn gain down, if that speaker works move on to the next thing in the chain.
