Timing Tool
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
For a DIYer a cheap Laser set will be fine as long as you dont mistake it for a locking tool as it will bend and/or snap the cams. Its only supposed to hold the cam position whilst you use another tool to lock/unlock the pulley retaining bolts.
The laser set from eBay is around £45
Cheers Mick really appreciate your input, a good friend of mine has been a mechanic for some years so he should be ok, I just wanted to make sure we had everything required. He has other Renault timing tools thats why I asked the original question. Thanks again Mick much appreciated
  182/RS2/ Turbo/Mk1
As per this, Make sure your friend is well aware that it is NOT a locking tool and he should be fine with the cheapy one if he knows what he is doing.
