16v_jon said:You need pedal, cable, Throttle body, TPS, ICV from the mk1 172 also you will need the ECU from the mk1 172
I think jons saying a big swop of bits, swop the ECU then wire the phase 1 ECU up and fiddle the wiring etcmatty w said:i think the looms are completely different and the pedal box,theres custom bits required
edde said:I think jons saying a big swop of bits, swop the ECU then wire the phase 1 ECU up and fiddle the wiring etc
Another idea would be to remove the UCH and swop all the wiring for a phase 1 wiring and ECU you'll loss the crusie and a few other bits but the phase 1 is much easier to fix. there no UCH to break and fail.
I know but its give people an idea what to do.matty w said:its not as simple as just swapping bits
