Stop and handbrake light on
Clio182mike
  Clio 182
Hi everyone, my handbrake and stop light are constantly on. I have checked the fluid level first but that's fine. I inspected the pads and changed the rears as they looked a little low but the lights still remain on. Any ideas on what I can check next? Is there a sensor sticking or something simple?
wms_f1
  172 Cup
@Clio182mike Did you get to the bottom of this issue?
I have the same issue - brake fluid is fine, and pads all ok.
Any help appreciated.
Ta
wms_f1
  172 Cup
Hi, it turned out to be the rear caliper was leaking so I had it replaced
Thanks for the reply. Will check the calipers/hoses for leaks.
Do you recall if the brakes felt fine at the time? Good pedal feel?
