Standard OE pads from GSF P/n?
  clio 172 cup
I'm going to replace my pads with standard OE pads until I can afford to upgrade my fronts for ferodo's. I'm going to GSF and have seen on here that the rear pads are p/n N64109 which are in the megane section. So just need to know what the p/n is for the fronts, as not sure looking at the GSF site.
  clio 172 cup
They are the Textar pads. Is that right? I thought they were bendix pads.
Here are all the options in the meg and clio sections:
R64274BRAKE PAD SET-TEXTAR MEGANE 2.0 16v >4/99 27.30 Add R64274BBRAKE PAD SET-BENDIX MEGANE 2.0 16V >04/99 23.50 Add R64276BRAKE PAD SET-TEXTAR MEGANE 99> 28.90 Add R64276BRAKE PAD SET-TEXTAR MEGANE SCENIC 99> 28.90 Add R64276FGBRAKE PAD SET-EBC GREENST MEGANE SCENIC 99> 42.00 Add R64276FGBRAKE PAD SET-EBC GREENST MEGANE 99> 42.00 Add R64282BRAKE PAD SET-FR MEG 2 02> *** 32.60 Add R64282BRAKE PAD SET-FR SCENIC 03> 32.60 Add
N64005BRAKE PAD SET-BENDIX CAL CLIO (BENDIX WEDGE TYPE) 13.80 Add R64220BRAKE PAD SET-GIRLING CAL CLIO GIRLING 14.10 Add R64221BRAKE PAD SET-GIRLING CAL CLIO GIRLING 18.50 Add R64221AGBRAKE PAD SET-EBC GREENST CLIO GIRLING
  clio 172 cup
They are the textar pads is that right? I'm sure you know more than me, but I thought they were bendix.
Below are all the options in the meg and clio range if that helps:
R64220BRAKE PAD SET-GIRLING CAL MEGANE GIRLING 14.10 Add R64221BRAKE PAD SET-GIRLING CAL MEGANE GIRLING 18.50 Add R64274BRAKE PAD SET-TEXTAR MEGANE 2.0 16v >4/99 27.30 Add R64274BBRAKE PAD SET-BENDIX MEGANE 2.0 16V >04/99 23.50 Add R64276BRAKE PAD SET-TEXTAR MEGANE 99> 28.90 Add R64276BRAKE PAD SET-TEXTAR MEGANE SCENIC 99> 28.90 Add R64276FGBRAKE PAD SET-EBC GREENST MEGANE SCENIC 99> 42.00 Add R64276FGBRAKE PAD SET-EBC GREENST MEGANE 99> 42.00 Add R64282BRAKE PAD SET-FR MEG 2 02> *** 32.60 Add
N64005BRAKE PAD SET-BENDIX CAL CLIO (BENDIX WEDGE TYPE) 13.80 Add R64220BRAKE PAD SET-GIRLING CAL CLIO GIRLING 14.10 Add R64221BRAKE PAD SET-GIRLING CAL CLIO GIRLING 18.50 Add R64221AGBRAKE PAD SET-EBC GREENST CLIO GIRLING 36.50 Add R64225BRAKE PAD SET-BENDIX CAL CLIO BENDIX WEDGE THIN TYPE 16.90 Add
I don't want the greenstuff either, just the standard pads.
