Some Kind of Relay Need Help Plz!!!!!!!
Hi, i was wondering if soembody could help me, my clio a 91 model has started to lose functiuons!! st the windscreen washer wouldnt stop when applied!!! now when on normal headlight, the high beams will not lick on, but flash when light s r off! and also the washer spray does not wrok at all now............any input would be very helpful.
Sidd
  Revels Mum & Sister
Yeah check all the relays mate.
Sounds like it may be something else. Have you had any water get near the fusebox and relays. Trying changing some fuses
  Clio II 1.4 Priveleg
If you are unable to FLICK onto main beam when the lights are on dipped beam, then that is a faulty light switch, it will need to be replaced even though they will flash with the lights OFF!
Also sounds like the wiper switch has also given up. Try a replacement.
Hope that helps.
Bob RTE
