Snapped a rear arch liner bolt!
  182
I was trying to take the rear bumper off and started with the arch liner, didn't give it much and the bleeding thing snapped off, now one of my liners is flapping about a bit and clashing with the damper.
Is it a BIW bolt/stud? Anybody got any suggestions on how to fix it back in to place? Is it worth getting another stud welded on so I can retain the liner with another washer and nut? Or is there some sort of non-permanent glue I could use?
Mr R.
  A special one.
It's a welded on stud, you could drill through it and fit a bolt or hold the arch on with some sealant.
  182
Cheers, might try the sealant idea as I'm not sure I can reach through behind to torque up a bolt? Gaffa tape will have to do in the meantime!
Drill through. Bolt from behind boot carpet. Nut. Then arch liner. Then nut
The first nut keeps the bolt there for if you need to remove the arch liner again
