can we put this on our Clio? wat will be the cost?
http://www.swrmotorsport.com/main/6_speed_sequential.htmhttp://www.swrmotorsport.com/main/6_speed_sequential.htm
Quote: Originally posted by telford_mike on 25 November 2002
Yes you can put a SADEV sequential gearbox into a Clio 172. The Clio Cup Race cars have them as standard. I think they cost around £6,000, plus fitting. No good at all for use on the road (can only change up when at full throttle), but great on the track. Needs rebuilding every 6,000 miles apparently.
Hi,
watabout using Renault Trafic Van 6-speed gearbox?
Cheers,
KK
Quote: Originally posted by BenR on 26 November 2002
there you go....
teh new 6 speeder will still fit the as the hosing bolts are the same. but if you wanna use it is up to you, no real need really....driveshafts will need to be changed though.
but the new megane uses teh same F4 units though....renault aint develooping a new engine at cost for ages ntil they get their moneys worth....were still on the same V6 for gods sake!
oh, you can chage gear on the sequential whenever you like......even off the throttle.....or part throttle.....
Hi benR,
the 6 speed gears using on Megane is it the same on the Trafic?
cheers,
KK
Quote: Originally posted by Steve on 27 November 2002
End of the day I would rather spend a fraction over a grand and have a 70 bhp nitrous on progressive and a quick shift gear linkage.....
How would a superchip give you 70 bhp?
