scuttle drainage
  iceberg phase 2 172
hi does anyone have a pic of the pipe that gets blocked on a ph2 ? as i cant find it at all .. or if anyone could give a detailed description as how to find it would help :)
There's 3
1 in each corner, driver's side is easy to see once the scuttle is out, passenger is a bit more hidden by the washer bottle.
There is also one right in the middle, this drains out of a hole in the sound deadening on the bulk head.
Might I suggest removing the arch liners at the back of the arch and getting rid of the crap that usually builds up behind there as well :)
  iceberg phase 2 172
thanks mate , just looked , the drivers side was blocked , also the the pipe in the middle was blocked , both cleaned out now though :) thanks again bud
JoshOm3
  Cup'182/Rs2'd Trophy
There's 3
This will be a problem with your wet footwells too.
