2118'd Iceberg Ph2 172
Ok, tried searching, no luck. I have Koni (not sure if adjustable or not) dampers and am trying to remove my top mounts. They don't seem to have allen key sockets in the middle of the 21mm nuts like the standard ones are supposed to. They have a 10.5mm or 11mm nut, with a little tab that spins. Could this be a damping adjuster? They don't click though but do spin freely.
When I try "shocking" the 21mm nut with a socket, as kind of expected the top of the dampers just spin.
Tried using mole grips (yes, slight bodge, but Halfords don't sell any 21mm dished or dogleg spanners!) on the 21mm nut and got an 11mm socket on the nut on the shock and the socket rounded. Tried a 10mm and it wouldn't fit.
Would an impact wrench work? I'm assuming it helps with the car on the ground to push the shocks onto the struts? What about a bent 21mm spanner on the big nut and mole grips on the silly little 10.5mm nut on the damper? Is it usually a fair bit of torque that needs to be applied?
Thanks!!
:S
Thanks!!
:S
