Removing rear wheel bearings
I need to stick my rear wheel bearings into my new brake discs.
I have a hydraulic press, so is it just a matter of a big socket and press and force the mofos out?
Smokey
Has
  RS 182 - Black Gold
Yup just make sure its the right size place it over the end of the press.
if its a top down press place a towel under the bearing or something.
keep pumping it will move and take a bit of force.....
you will hear a click then BANG the bearing shud pop out of the disc, carefull with ur ears !!! its loud
  Turbo'd MX-5 MK4
question, is it only the rear bearing that need to be pressed into the discs? or the fronts as well? and if changing the whole brake setup after 36k, is it worth changing all the bearings too? or is that OTT?
Fronts are in the hubs not in the discs. If you are buying discs from renault the rears come with the bearings already pressed in so its a straight disc/bearing swap in one. Piece of piss.
