Rear shocks & spring fitting guides
  PH1 172
Can anybody point me in the right direction to find these as I have a set of Eibach Sportlines and new standard shocks to go on?
  Lots of Alfas
Terry the shocks is easy, you just jack the back up, stick it on some stands (on the frame not the suspension!). Unbolt the lower bolt holding it to the trailing arm, then unbolt the nuts under the rubber caps in the boot. Once the lower bolt is off the springs will pull out. Make sure when putting back together the correct torque settings are applied.
Its only 1 bolt and 1 nut for each side.
  PH1 172
Cheers mate:D
