Questions on a 182 rep
I have acquired the front wings and front bumper to install this weekend. Only issues are the wheel arches - would my standard DCI ones fit, or do I need to order the 182 ones because they're flared wings?
Second question - I have the xenon projector lamps but will use my own ballast and ignitor kit (not the one that comes pre-fitted). What size bulbs are they, presuming they are H7 that fit in the lamps?
Knuckles
ClioSport Admin
You need the front wings/arches, front bumper, arch liners (front and rear)*, rear bumper and a replica exhaust to make a 182 replica.
I can't help with the bulbs though
*i didn't bother with the larger arch liners. I cut my front ones out to accommodate teh lowz to be honest.
I was initially going to consider a 182 but it's cheaper to do a 172 as I won't have to fork out £500 for the modified exhaust. I suspect the 172 has the same front setup as 182? I don't know if the 172 rear bumper is much different to the DCI, but I don't think it can be very expensive - unless that needs new rear arch liners too.
You cut out your old ones, did it sit correctly/safely?
Knuckles
ClioSport Admin
They're the exact same parts bar the exhaust cut outs.
The rear bumper is wider than the standard one so requires larger arch liners.
But I just left my standard ones in, iirc there was around an inch worth of gap at the very bottom.
Yeah, it was fine. It was melting/rubbing on the wheel when turning so I chopped them out
Won't the headlight and other things be exposed if the front one is missing? I'm on the lookout for a pair on eBay but I won't get it in time for my EU trip which is concerning in case its wet etc.
