Powerflex Bushes
  Porsche GT4
I want to order the front powerflex kit for my cup & i'm being asked the size of the anti roll bars, inner 23mm or 25mm outer 22mm or 23mm.
I haven't a clue, any idea's?
Thanks for any help.
MarcB
  Too Many
The bigger sizes are for trophies & Cups.
So if i wanted to do my ARB the sizes i would need are -
Inner ARB = 25mm
Outter = 23mm
Im sure if you actually look at either the k-tec or KAM websites it tells you this.
DaveDreads
There you go mate, i've just done my arb so I went through all this the other week.
Clio Ph1 2.0 16v RS-172: Outer mount - 22mm, Inner mount - 25mm
Clio Ph2 2.0 16v RS-172: Outer mount - 23mm, Inner mount - 25mm
Clio Ph2 2.0 16v RS-182: Outer mount - 22mm, Inner mount - 25mm
Clio 2.0 16v RS (172 & 182) Cup / Cup pack models: Outer mount - 23mm, Inner mount - 25mm
DaveDreads
Not easy tbh, I had the use of a lift and two mechanics so we took the subframe off
and did it the easy way by lying the subframe on the floor.
I can't imagine how much of a ball ache it would be lying under the car with it on axle stands.
  182
I done it last week on the drive;)
Not something i would recommend though, the outers are very easy but the inners were a ball ache!! I used longer bolts and slightly elongated the bracket that goes round the bush.
Made it easier to do but still fiddly as hell! Could change a clutch in the time it took me to do the inners lol.
You need 45mm x M8 bolts.
p@blo
  Clio/A3
Heard the longer bolts help with locating the brackets. Was a royal PITA with the std ones :(
