Not ideally, especially the water pump. Cambelt needs to come off to change the water pump iirc.
Yeh just checked your safe on that one, couldn't remember if the pump would clear the belt if its fitted.Cambelt only has to come off on the 197, on the 172/182 its all driven by the aux belt. Not sure what they mean by play, are they making a noise, does the water pump leak or whine when engine is cold?
£1K to fix? they're having a bubble bath
a new PAS pump is about £300 and a water pump about £60, can be done in under 3hrs
