ITB Hybrid+Cup+Scenic II
Reading some threads, it seems that almost everybody is unhappy with the service (no service) tha the Reno dealers provide... It is also no secret that they are not very good at helping out with spareparts and so on...
Sooooo... I have made up a little list of various parts that you might need for your Valver/Willy! If you give them the number they might be able to help you... As half their job is already done!
77 00 810 879 : Temp gauge sensor
77 00 737 571 : ECU temp sensor (black or white connector)
77 00 300 334 : Circulation pump/fan sensor
77 00 737 572 : Manifold air temp. sensor
74 01 317 957 : ISCV, Idle Speed Control Valve (might be cheaper to order at a Bosch dealer, it has a number stamped on it)
77 01 203 513 : Throttle pot. meter
77 00 855 719 : Timing sensor (get it at BBT)
77 00 834 918: Oil pressure warning light sensor
77 00 843 236 : Oil pressure gauge sensor
Hope I got it right... BTW most numbers for the Clio start with 77... If its a part starting with 60, its a genuine Renault Alpine/sport part...
Hope someone can use this....
Michael
