Painting the front grills
  RB182 & Storm 200
Im thinking of painting both fronts grills black, they are currently grey but looking a bit dull. Is it worth sanding first using primer before spraying?
  E46 325ci, ZX10r E9f
i just sprayed the grills on the wife's scenic and just cleaned them and sprayed them with plasti kote
  bg 182
its not going to hurt you, helps the primer key into the plastic, use an etch primer eats into the plastic better too.
