Oil leak...
  Renaultsport Clio182
My 182 appears to have a oil leak coming from the rocker cover, looks to be comin from the bolts which tighten it down. Just wondering, do the bolts have a rubber (or the like) seal?
Is there a simple fix people use for this? Would prefer to just get new seals for it but don't think you can buy them separate? No really wanting to buy a full gasket kit just for a few rubber seals
cheers guys!
It's a silicone gasket. You can take each bolt out one at at time and put a bead of silicone around them. But ideally it needs to come off and be resealed when the belts are being done.
Done now, done ma belts for £200 so can't complain! So aye, just take the bolts out n slap bit silicone on them should fix it?
MarcB
  Too Many
When mine was in at SWR all my rocker was sealed as it was leaking badly.
The only reason I noticed this is cause it was bright green sealer that was used as it was not there before
