now im worried...............
when i pull off slowly i feel a vibration in my accel pedal and you can hear and feel a vibration going throughout the whole car and then once im movin its ok i slighty feel it when changing up gears and feel it a little more when slowing down the car through the gears
what the hell is it ??????????? can some one please put my mind to rest
[Edited by 6secClio on 25 July 2005 at 3:26pm]
maybe but if i pull off and hold the clutch in a certain place it will just keep on vibrating not good (unless your female of course)
i think it might be a bit more then not enough rpm as when i was decated it stoped for a bit nows its back
  Not a Clio
Well you havent got TC so it cant be that playing up.
If its only when you pull off slowly I would have thought not enough revs, i dunno.
What does the car idle like?
well i aint no engineer, but you said that when you hold your clutch in a certain place, your car shakes. better check the cluch first
  don't
my old clio was like this for ages
was worse when pulling off in slow moving traffic on a slight hill
would seem to struggle and vibrate, never got any worse or better so i just left it, presumed it was a clutch problem so was scared to go near it incase i needed to spend lots of £££ :)
i just put up with it and revd it quite hard when pulling away on slight hills
  172 cup'd extreme
its none of the above.... its the engine stabiliser mount or dogbone as some people call it #30 new and 2 mins to change
  don't
that makes sense ^^^^^^
common problem
had mine replaced twice in a year so it must have gone again, first time it was replaced the old 1 was snapped right in half lol
well i had my mounts done at bb performance and on the way home that day it was bunny hoppin and lurching all the way home when i got back i adjusted the accelerator cable and it seemed ok except for the vibration and the gearstick still has alot of movement in it
dave rsi has got the exact feeling that i get
[Edited by 6secClio on 26 July 2005 at 2:31pm]
  don't
almost, my mate now has this problem, sold the clio to him, he hasnt mentioned it though
not quite sure what it is really, guess its just too much movement of the engine/gearbox, so could be the mounts
is a bit of a pain though, especially in slow moving traffic on slopes
of the car is stuttering from low revs then CHANGE YOUR FUEL FILTER - its probably full of crap, clogging the engin - i did this when mine was stuttering and the differece was incredible
yeah cool i shall give it a go do all fuel filters standard things are can i invest in an increased flow filter or some thing like performance air filters
