Normal or Knackered ???
  172 cup trackday
Just fitted some FK Konigsports coilovers, covered about 50 miles.
whilst fitting I made sure that the spring adjusters had the same settings for both sides of the front and rear.
Ride height was perfect to start with but on the weekend I noticed that the near side rear had dropped lower than the off side rear.
Got underneath, everything was as I left it, marks on spring adjusters and distance the same.
To get the height some where near I had to raise the near side about 4 turns, now the adjusters are completely different distances away from the spring base/beam, Is this normal ???, the car is stripped out and carries hardly any weight on the rear, so I would of thought that the spring adjusters should need to be about the same ?
I'm thinking maybe I have different springs ?, although they were out of the same kit and measured the same out of the box.
Paul
